Motor has 155k on it. I put on all new gaskets and head bolts. Its got a fuel pin and gated hx35 turbo. Stock injectors. New waterpump lift pump and ps pump. New belt tensior and belt. New filters. You can hear it run as its in the truck. It wont be pulled until i have cash in hand. I want $2000 for the complete motor minus the flywheel and clutch. Ill let the flywheel and clutch go for another $200 and the 4wd 5spd setup go for $850. Trans has a new rebuilt top plate and hydros. It may need the 1st/2nd gear syncro. $2700 if the same buyer takes it all. Im located in wv
Some pics and a couple movies.
