1 - 16 of 16 Posts
92 ex cab v6 toy. sas. dual cases. $3000 takes it
Lookin to get rid of my daily driver. 92 Toyota Extended Cab. V6 which has been replaced, but i dont know how long ago. It had the heat tags on the rear of the cylinder heads ( the void if removed melt off tags ). The odo reads 226k miles. Runs excellent and has no oil leaks , or dont burn any oil either. Originally a automatic. I just put a 5 speed, new clutch and new flywheel in it. The timing belt and water pump were just replaced as well. Power windows and door locks, but the locks work when they feel like it. the airconditioning does not work, but everthing is there, minus the belt. Body is in fair shape but the bed sides are bent pretty good.
The front springs are out of a jeep wagoneer, the rear springs are stock with a 2nd leaf out of a superlift 3" lift and a 2" block.
The steering linkage is homeade, and should be replaced, but is working fine for me.
The dual case crossmember is home made out of a marlin crossmember for a four runner. It is Not flat belly.
  1. 1.5" wheel spacers
  2. landcrusier front rotors
  3. ifs calipers
  4. TG front hanger
  5. TG front shackles
  6. TG u bolt flip
  7. TG high steer arms
  8. Marlin v-6 to 4 cyl adapter
  9. Marlin dual case adapter
  10. Marlin 4.7 gear set - 21 spline
  11. Milemarker 9k winch
  12. home made front bumper -pipe
  13. home made rear bumper - pipe
  1. 35" procomp extreme all terrains
  2. new 17" black steel wheels
Make me an offer, not necessarily looking for any trades. Located in maryland.
Will get some pics up soon. FIRST $2800.00 TAKES IT
Not only that these forums require a price or your ad will be deleted.
So come up with something
Discussion Starter · #12 ·
$ 2500 or i might just part it out... someone has got to be looking for a 4.7 doubler set up and manual trans for a v6 yota !!!???? make offers on the parts you might want and let me know'
Discussion Starter · #13 ·
come on, i will even throw in a completely driveable 94 2wd standard cab 4cyl, its in really good shape, just needs a title
Discussion Starter · #16 ·
i know some things are home made but seems like a good price on a starter... maybe im missing something... :confused:
just need to get rid of this to help pay for the new buggy parts list !! with the gearing and the wheel base this thing suprises alot of people on the trails around here.
Hell, i am even throwing in a good daily driver 2wd for parts ( has no title )
1 - 16 of 16 Posts
