1 - 7 of 7 Posts
V6 3.0 engine that I am parting out. I have all parts to a 3.0 in good condition except the block which isn't all that bad but I am not going to sink anymore money into. Buyer pays shipping. All parts obo.
Rebuilt heads w/new exhaust valves, all new valve seals, guides. They have been surface, and pressure tested. Valves have been fully adjusted. 500.00 including new head bolts from engbldr.
Valve Covers 25.00
Upper and lower part of Intake manifold with throttle body 75.00
Injectors that have been cleaned by cruzin performance. 100.00obo
KN drop in air filter 20.00
ECU 4x4 a/t 25.00
MAF 25.00
Exhaust Manifolds & Cross over 50.00
Fuel rails 25.00
EGR 20.00
Distributor 50.00
Reed valve 25.00
Power Steering Pump 30.00
Anti lock ecu 10.00
Flex plate 10.00
Air box 10.00
Rear Drive Shaft 30.00
Fan Bracket assembly 100.00
I have misc stuff bolts, brackets etc
Knock sensor 10.00
Short block needs rebuilding 100.00
AFM
I do but I think it's the MAF, AFM came out later I not for sure. I don't know at this point if I will be able to use it or not for my swap I will find out on Monday and let you know. Thanks Brandon
Just the engine and tranny or you looking to get rid of anything else on it?
Im looking for a front dif if its a 4.56.
1 - 7 of 7 Posts
