1 - 5 of 5 Posts
Ok so I’m installing this motor I got for a good deal in my 93 runner. Everything seems to be the same but one plug. The white plug next to ecu. Is there a write up on this to maybe fix my issue. Already installed the motor and thought I looked over all the plugs.
Please Help guys
Thank you!!!!
1993 5vz swapped 4runner
Did one truck have an auto and one a manual? Do you happen to have a photo of the plug you're talking about?
Interesting -- I know when i did my swap from 3vz--5vz (not what you're doing here I know) I had an extra plug on the harness because the motor came from an auto but the ecu was from a manual (iirc). Either way I have an extra plug similar to that one after the swap that does not have a spot in the ECU. Everything works just fine and I haven't had any issues so I hadn't thought about it.
1 - 5 of 5 Posts
