1 - 7 of 7 Posts
Custom 1993 Jeep Wrangler Rock Crawler
Axles: Dana 60 8 Lug 1 Ton Rear: 5.13 Gears Detroit Locker 35spline Axles Shortened To Wrangler Width 8lug Disc Brakes
Dana 44 High Pinion 8 Lug ¾ Ton Front:5.13 Gears ARB Airlocker High Steer Conversion New Upper And Lower Ball joints Custom Differential Cover Warn Chromemoly Axle Shafts Inner And Outers Premium Warn Locking Hubs Dual Caliper Disc Brakes Narrowed To Wrangler Width
Steering:AGR Crawler Steering Box With Highsteer Turns the 37” tires easily
Motor/Running Gear:Chevy 93 4.3 V6 60,000 miles – fuel injected
700R4 4speed Automatic Transmission 241 Transfer Case With Eliminator Kit Beefy High Angle Rear CV Driveline
Suspension/Tires:3 Link With Panhard Bar Up Front – axle moved forward for longer wheelbase 4 link With All New Dom And Joints in Rear – axle moved back for longer wheelbase Nitrogen 2.0 Fox Air Shocks - 14" Long Travel
Suspension – Awesome Shocks Custom shock hoops front and rear – front goes into engine compartment, rear goes through the floor where the seat is supposed to go 37" Parnelli Jones Dirt Grips 80% Tread 16" Steel Black Rims
Accessories:Custom skid plate under transmission and transfer case On Board Air – A/C Pump On Motor Block Converted to Compressor and Tanks in Rear - 2.5 Gallon Tanks ARB Compressor Side Rock Lights 20Gallon Aluminum Fuel Cell B&M Shifter On Floor Optima Yellow Top Battery 02 TJ Wrangler Seats Flow Master Exhaust – Sounds Awesome Center Lock Box Soft Top With Bikini Top Grant GT Steering Wheel 10,000lbs Winch With Thick Cable Custom motor mounts Fender flares, Custom rocker guards
I have had no problems with this truck just selling to buy a house and dont use it much to keep it
$First 7500 takes it and thats a hell of a deal
Located in Puyallup Washington but travel often to oregon
call anytime (541) 326-7086 brett best way to get a hold of me is calling
1 - 7 of 7 Posts
