1 - 4 of 4 Posts
I have a 94 Blazer that drops oil pressure under these conditions:
In 4 wheel high with 4 passengers and gear we were pulling a 5 mile grade offroad between 10 - 20 mph, then we heard the lifters start rattling and noticed the oil pressure gauge was reading almost if not all the way low. As soon as we turned around and went downhill the gauge read normal again and the rattling stopped. We checked the oil and it was full. It did this one other time while heading up in the snow.
Driving in town and coming to a complete stop the pressure dropped very low (lower than normal that is) and upon taking off it regained pressure and didn't drop that low again.
Has anyone had this problem? We are planning on dropping the pan and checking the pickup to see if it's clogged anywhere.
Thanks.
82000 miles on it and it seems to be when it's heading up an incline that the pressure is lost, not sure if creating more of a load or putting the oil at the rear of the pan is creating the problem. Dropping the pan will show any obvious reasons, but if everything looks normal when the pan is off I'm not sure what to do besides putting on the high volume pump.
1 - 4 of 4 Posts
