1 - 20 of 227 Posts
This build started out as a Jeep that I was going to take back to stock and put some Toyota axles under. My plan was to use it as a DD every once in a while. Well, fast forward to the day I go it, and I figured out that there had been plenty of redneck fixes on this thing that would turn the build another direction. I traded an old 4 wheeler for this clean titled Jeep straight up. When I got it, it didn't run and was pretty rough around the edges. I quickly decided the only "logical" thing to do was to buggy it out. So plans changed and I started planning how far we would go with it.
This is probably my favorite build I've done so far for the fact that my dad is assisting me throughout the entire build. He has never been able to help out since he's always lived 6+ hours away until recently. It has been a great experience teaching him the tricks of the trade along the way.
Current plans/specs:
94 YJ tubed out, boat sides, dovetailed & stretched 12 inches over stock for more cargo space
Engine: Fuel injected 2.5 (Will keep this engine for this build & will eventually replace it with a 5.3)
Radiator: Volvo fan & relay combo
Transmission: SM420 Granny 4 Speed
Transfer Case: Flipped Dana 300
Driveshafts: non-cv driveshafts from Tatton driveshaft
Front Axle: 2005 & Up Super Duty Dana 60 with high steer, spool, & 5.38 gears
Rear Axle: 2005 & Up Super Duty Dana 60 with high steer, spool, & 5.38 gears
Wheels: TWF 12 Bolt H1 builder kit with rock rings and pressed centers
Tires: 47" LTBs
Shocks: ORI struts on all 4 corners
Steering: PSC full hydro 4 wheel steer kit
Suspension: 4 link front and rear
Seats: Corbeau JP seats in front and Corbeau Baja SS low back in rear
Belts: PRP 3.0 5 point harnesses in front, PRP lap belt in rear
Fuel cell: custom aluminum cell with stock YJ fuel pump setup
Wheelbase will be in the 120" range and the Jeep will be tagged and registered when complete
A couple builds/builders that gave me a lot of inspiration:
One more YJ on rocks by trailpunisher
Jim's Garage
La Bamba Gone Gangster by nodenaro
Twisted customs
Liquid Iron Industries
I'm starting with the rear first, then will move to the front. In the end, I'll have about 3' of stock frame left on each side.
On to the pics:
The day I cleaned it up and brought it in the garage
Discussion Starter #5
Sitting next to my TJ:
Tube work continued:
Added a slight bend to the lower tubework to get a flat belly without lifting the body
Discussion Starter #6
I ended up changing the rear corner tubes because they didn't end up matching up with the top tubes and I just didn't like the way they looked. Some of these pics are before I changed them though.
U done eating yet?........This looks interesting, and I like the fact that when you cut something off, you drag it out into the street/alley to take pics....lol
Discussion Starter #10
Yeah, building a Jeep in a small 2 car garage in the middle of Houston makes things a bit more interesting. Good thing is, if I ever want to get rid of something, all I have to do is move it out to the street, and 10 minutes later someone has picked it up and is on their way to the scrap yard with it.
Didn't know you where back, I was thinking you were still in CS. Definitely a cool build, let me know if you need any help cutting things off. I'm better at that than putting it back together.
Discussion Starter #13
Did you just bolt your tube bender to the concrete in the alley way? Fawking awesome if so. My HOA would hang me at the community pergola if I did some shit like that. Subscribed!
Yeah, I used 5/8" threaded inserts so when the bender isn't mounted, there isn't anything sticking out of the ground. No letters from the HOA yet so I think I'm good to go lol
Discussion Starter #14
Yeah, I've been in Houston for almost 2 years now. Thanks! Will do. Most of the stuff that I take off comes off with a sawzall or cutoff wheel which makes disassembly pretty quick. :laughing:
Discussion Starter #16 (Edited)
Mounted. I welded the rock ring with the TWF logo sitting at the same location as the valve stems. This will make it easier to locate them when airing up/down. These things look sharp. This is my first set of H1's and was by far the easiest tire install that I've ever performed with a bead lock. Definitely my new favorite rim. My TJ will likely get a set once I tear it down for a rebuild.
More or less where it will sit once the rear axle is in place.
Discussion Starter #17
Picked up some Super Duty axles yesterday. All of them are 05 & up models. This should get things rolling a little quicker. Anyone thinking of using one of these axles, make sure to have a strong buddy with you when you unload them. It took everything we had to get them moved off the trailer and put on stands in my garage. I'm guessing they weighed about 700-800 lbs. each. These things are huge!
Did you plasma your brackets off? Were just starting on my sons 05+ D60 trying to figure out best way to tackle it.Ive heard some say portaband works great but I dont see how thats the best option.How thick are those radius arm brackets?
1 - 20 of 227 Posts
