1 - 5 of 5 Posts
I have a 95 PF with 2 sec of injector on time (not milliseconds in fact it will almost maxx out the Vantage scope on its highest scale), all 6 fuel injectors ohm out to 12 ohm's, coolant temp sender ohms test good at 65*F, TPS closed switch works, computer grounds are good, I'm suspecting a bad computer (spendy guesstamation) any ideas what eles I should check? :confused:
I'd check your Vantage. (j/k) Do you have the time scale right?
I will check another rig with it Mon. and see
Does it run at all?
fairly sure It will when I put new plugs in it, there fuel fowled pretty bad.
Have you put a noid light on it?
Yes it flashes a noid light guess I never thought to look and see how long it stayed on for
Does it do it with the O2 sensors unplugged?
I will try that to
truly good advice thanks :beer: :cool2:
Ya know a guys invests $2300 for a meter and some extra stuff to go with it and I would hope it would work good enough to not make an idiot of me.
Well here is what I found. The noid light was not staying on for any where close to 2 seconds, so I doubted the meter and fixed the car, the AFM had a shitty plug and the O2 sensor would not switch off of lean repaired both put plugs in it and she runs great.
:shaking:
1 - 5 of 5 Posts
