1 - 4 of 4 Posts
My rig wont start because the computer isnt priming the engine with fuel..I cant find this part anywhere...Should I just upgrade to a "JET Performance Chip"?...instead of payin the stealership over $500 for an OEM computer:laughing::laughing::laughing:
The Jet chip has nothing to do with the fuel pump. The computer provides a 2 second prime(via a ground wire) to the fuel pump relay. If your computer is fried, it is fried. You can check to see if your fuel system is operating by finding the grond terminal on thr back of the relay, and using a jumper wire to quickly activate the relay. Of coare you have already checked to make sure the relay is good and that you are getting the correct power to said relay. If this trick works, that you have an interuption in the circuit, or your computer did actually take a crap.
1 - 4 of 4 Posts
