1 - 11 of 11 Posts
This one has got me beat for the life of me. I can't seem to find a lift for a 97 4 Runner. Lookin for a friend of mine who wants a little more aggresive look on her rig. Nothing for major offraod, just for a hot chick in a sweet runner. Any help would be great. Thanks.
Yeah, I've checked all those out already. Thats where I started. Everything for the 4Runner seems to stop at 95, nothing beyond that. For lifts newer than that, thay have stuff for Tacos. Are the suspension set ups similar to where you can swap parts and possibly use a taco lift? I'm lost here.... :confused:
try a wagoneer dana 44 and a set of rancho 44044 leaf springs. in the rear, all pro's 4-5'' 56'' long leafs will probably suit your rig well. you can use the earlier model 'ifs' steering box with a 'crossover' system, instead of the rack and pinion
Try the TTORA boards. there is a guy on there that goes by cornbredNE that makes spacer lifts for it.
Yes, Tacoma's and 4Runner's use the same front suspension. But where the Taco uses leafs in the back Runner's use coils and links.
Check this article to help you figure out which way to go for the front.
http://www.trailslesstraveled.com/viewarticle.php?id=53
And to lift the rear to match, I'd suggest using Old Man Emu coils and shocks, they will give about 3".
If you want more total lift than 3" without using long-travel or a straight axle, add one of Rogers body lifts to get a few extra inches.
Of course you could just use some really cheap coil-spacers for only a few hundred $ total but the ride will suffer...
1 - 11 of 11 Posts
