1 - 4 of 4 Posts
i have a 97' and I'm getting a 3" CalMini Suspension lift on it. My next step is to get black wheels and mud tires, but i dont know what sizes will fit. I want the largest tires on her. Can anyone point me in the right direction? Thanks
I had 32s with the calmini kit on my truck with factory lego wheels. you can fit 33s but you will have to trim the front fenders in the rear.
Discussion Starter #3
32s. right on. how did she ride on them? stock wheels on the 97 hard body are 15's correct? just checking, because i have chrome and i want to get some decent black 15's
Banned
I use 32" up front on a 2wd Hardbody with no real problems untill I compress it hard at RR Crossings or hit drive ways at 40 or steep down hills a little to fast. But Both fenders flex outward, totally disconnected at the bottom. The 4x4 has a 1.5" body lift over the 2wd so I would think U should be good. I would like to ditch the front clip and move the cab back for better compression clearance since it has destroyed the cab... We need a rubber or poly front end for these damn things but no one makes it... SO eventually your Nikey's er gona get caught in yer Super Swampers
1 - 4 of 4 Posts
