This started off as a 2wd runner that I bought about a month ago. I started ordering parts and now its time to get it done
50-50 built for the trail but ok on the streetmkmarz said:plans? trail only? dd?
This brother knows how to get it done :grinpimp:4xguy said:thanks i will be the first to say safty never takes a holiday. yes the front is toyota longs 30 spline,arb,5.29s,trussed,high steer.w56 trany with marlins 23 spline 2.3 and 4.7 tc.Stock rear with 5.29s and arb![]()
x2e-hills4x4 said:are you using a front diamond axle? the stock toy will be to narrow. those are the same width as taco stuff
Good job on that shackle angle. Most peeps SAS's angles are non-existant4xguy said:front is lookin good could of finished but had to order a 3in longer drag link.Brake lines and shock towers done u bolts 100 lbs +![]()
I would think as long as you sleeved it correctly and had the correct offset shackles it should be just like any other trucktanman2003 said:is it possible to have the shackle go through the frame, or is a late model 4runners frame really wierd there?
