41 - 46 of 46 Posts
Discussion Starter #41
yep. you running assist steering or pump and gear?
I’ll tap the box and run the run of the mill size assist ram. Should be fine for driving down the road and getting into some rocks. Toss in a power steering cooler in the pot too.
Discussion Starter #42
Really want the track bar to be tucked in there. Doesn’t get any closer than this. Don’t think I’ll be needing a bend in it either. Got to chop off that bottom through hole for sure. This is still ‘full bump’ on the front.
I haven’t finished plating the rest of the unibody in the area but this is where I plan on having it.
Discussion Starter #44
The shock towers went in nice but I don’t want to take any chances so the cross brace is a must. Still need to tweak a few cuts to get it just right.
Discussion Starter #45
Not proud of how long this took to actually fit up. Drops right into place with no fuss! Truly one of a kind. On to the trac bar game.
Discussion Starter #46
Some more plating and tacked in trac bar bracket. Got to tack in the axle side bracket.
41 - 46 of 46 Posts
