1 - 9 of 9 Posts
anyone got actual measurements for the large and small Rubicon Express Superflex Joints? i need them because i want to begin building my parts for my SAS, but i don't have the cash to spring for the joints yet, also, need to know which ones i SHOULD get and won't know that until i know their sizes. thanks for info. ps-checked RE site, nada, checked a couple other sites, nada, called a couple local shops, nada. thanks for info again.
The big ones are 2-5/8" in diameter and the joint body is 1-7/8" wide. Then as Stinkbug said, the part the bolt goes through is 2-5/8" wide and uses a 9/16" bolt.
Are the big joints up to the task of dealing with 42's and a D60/14bolt? Are they comparable to the average rod end for strength?
FYI - I know the design of the links will affect the stresses put on the joints.
Eriks got it right when i asked this same question people gave me all sorts or stupid answers. cuz 2 1/2" is not 2 5/8ths
I'm going to go out on a limb and say that they are stronger than a rod end, comparing them dollar for dollar. I have been running them for two years with rockwells and 44s and other than greasing them 6 or 8 times, I have had no trouble out of them. I have seen a few expensive rod ends break while running the same trails.
A buddy of mine ran rod ends on his track bar and broke them fairly often. He changed to the RE joints and hasn't broken one yet (he did bend the track bar though). ;)
1 - 9 of 9 Posts
