1 - 20 of 50 Posts
So I've wanted to build one of these for a while and instead of working on my Scout, I decided to finially put it together. I wanted it height adjustable so that it could be lowered down to fit in the garage, yet raised up to get the higher stuff. It's wide enough to straddle the gooseneck, truck, etc. It works great for taking the top off the JK.
The uprights are 3' long reciever tubes that were purchased for another project that we never started. All of the materials I had sitting around except for the casters and hoist winch.
On to the picts....
On to the picts....
nice welds,what kind of weight do those casters carry?
Paint...
I have a reciever tube set in concrete on the side of my driveway that the tube bender mounts to. I stuck a piece of scrap in it to hold the main bar up for paint.
Discussion Starter #4
Discussion Starter #5
The details...
I drilled different sized holes in the 1/2" gussets to give me a place to store all of the various shackles, slings, and snatch blocks.
Discussion Starter #7
Harbor Freight hoist winch. I got the 1350# version and was very impressed with the quality and weight that this thing had. For the money it was well worth it. It is very quick. So quick that I hooked up the snatch block just to slow it down a bit. It would yank the top off the JK before I could get my finger off the trigger.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=2954
List price, $169 got it on sale with a 20% coupon and it was about $100 :smokin:
I also picked up the 2 slings that you see on the side leg. They were $10 each and are rated for 1000# each.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=44847
Discussion Starter #8
The trolley....
I had a whole bin full of these really nice v block pulleys packed with sealed bearings. 3 rows of 3 each gave me a nice smooth and distributed trolley. Used the plasma to trim down a piece of 6x3x.25" angle for the main brackets. Note that the hole in the middle will engage the holes in the main beam with a 5/8" hitch pin to keep the trolley put when I don't want it to roll.
Thats a really sweet looking project. My only .02 fwiw would be to drill one big hole in one of the black flanges big enough so you can fit the screw of a C clamp through it so you can clamp the trolly solid at any position along the top rail.
Discussion Starter #10
Last picts are of the finished project. This is the fully lowered position and fully raised position. Note that when dropped down, the 2" comes out the bottom to let it drop down further.
Lowered it's about 5.5'
Raised it's about 10'
I know we've all picked up stuff that we really shouldn't and have paid for it afterwards. Well at least I have. Hopefully this will save me some pain. I know I've used it at least a few times a week already.
Enjoy.
Discussion Starter #11
There is a hitch pin that goes in the trolly hole and into one of the main beam holes. The holes are 12" apart on the main beam and 6" apart on the verticals.
Awesome project and very nice job. Did you just make it up as you went or did you follow a plan? If you used a plan, was it of you own making?
Discussion Starter #14
I had made my plan and knew what I wanted before I started. Like I said all of the materials I had on hand so some of the design was tailor'd around what was around.
As for the rating difference between the hoist and the rest of it, I had much rather the hoist not pick up something as to have the gantry bend, break, or otherwise not be rated. If it's too heavy, then the hoist just won't cut it and I'm ok with that. I wanted good quality casters cause there is nothing more frusterating than cheap casters. The only thing I wish I had splurged on was I didn't get locks on the casters so it can sometimes get away from you on the gradual slope of the driveway.
Most things that I will be picking up with this are going to be 500# or less. Axles, camp box, tool box, tube bender, frame, Scout tub, JK hard top, etc. This should do all of that fine.
I build stuff
Great project.
Since the base (upside down T) is already tube, you might want to make up some extensions, or out riggers.
If something starts to sway at all while suspended it might tip over due to how narrow it is. BTDT with the Rover hard top, not fun. Re-did mine with a 6' base.
how do you lower and raise the gantry by yourself?
Great project.
x2
I like it I've wanted one forever, maybe I'll quit being lazy and build one.
Discussion Starter #20
I may eventually add some outriggers.
As long as the winch isn't on the end you're trying to lift, it's not bad. I slide a piece of 5/8" rod into one of the holes that gives me something to lift on.
1 - 20 of 50 Posts
