Adjustable shocks toyota leaf springs on sami
970 Views 7 Replies 3 Participants Last post by  Wontun Splodies
3
Fitted a set of hilux leaf springs with a spring under and revolving shackles setup. Hilux springs are similar to yj ones in size but here hilux ones are more common
Setup came out good, problem is which shocks to put in.
Any suggestion would be appreciated.
Tire Automotive parking light Wheel Land vehicle Vehicle
Wheel Tire Car Vehicle Automotive tire
Tire Wheel Automotive tire Synthetic rubber Locking hubs
Was thinking of an adjustable set but would not like to break the bank neither
1 - 8 of 8 Posts
Anyone did a similar modification maybe can shed light on type of shock and sizes of shocks?
There is no shock that is suitable for that application because a shock needs to be suited to the spring rate. the spring rate you have in compression is high because the spring is from a vehicle much heavier than your Suzuki and in droop you have no spring rate at all. This kind of folding shackle is an outdated idea that does not add capability to your vehicle, even if it looks like it is. My recommendation would be to put the hilux springs in the back, the rear springs in the front with a small chassis extension and a 100mm long, standard shackle and build shock mounts to use some soft valved 5125 Bilstein shocks. The car will be more capable and more trustworthy to drive on and off road than with the folding shackles.
The problem with stock leaf springs is that they tend to loose shape fast due to them being narrow. The setup I have adopted consist of front hilux leafs and reduced amount of leafs until desired outcome was achieved. This in return provide opportunity to add weight like for example winch
As for the revolving shackles, I am still experimenting but up to now it looks that axels are in more contact to the ground, hence less tyre lifting and less see saw effect.
Could be outdated but which modification replaced it?
3
Why is the leaf spring loosing shape a problem? Once any leaf spring is derated to the point it works properly under a Suzuki it can't hold arch. This is the nature of leaf springs and the Suzuki suspension design -it's not a problem, it's just what they do. Sure, you can increase spring rate and hold any height you want without sagging, at the expense of flex, ride quality and traction. In the photos you have posted the spring isn't really doing anything at all - and that's what happens with folding shackles -they stop the springs working - the shackle does all the work except that it doesn't have any rate - it's not pushing the tires down to generate traction, it's just letting them fall under their own weight which doesn't provide much traction - the wheels that are loaded (compressed) then have to drag the drooped tire out of the hole/rut etc it's in. Sure, the car might feel a bit better because there's less uncontrolled body movement but it doesn't translate to much added traction or capability. Dropping a tire a long way down into a hole means it has to climb back out again - especially if the car has open diffs. That's before you have to deal with the shackles unloading for instance, on the high side of big side angle. Some people claim they don't do this, I'd argue they haven't had their car in a position to have it happen.
Which modification replaced folding shackles? That's an interesting question to ask. They just slowly went away as people realised they have more disadvantages than benefits. I've spent 30 years working on Suzuki suspension. I've seen lots of ideas come and go. We landed on a RUF conversion with narrow tracked spring spacing with OME springs derated and soft valved shocks as pretty much peak performance for a leaf sprung Suzuki. This has been the case for 20 years. Lately, we've been experimenting with running a front panhard rod, which restores full steering lock on cars with soft front springs. We run this setup with twin locking diffs and with a tire size up to 35". It's not perfect - axle wrap is an issue with heavily derated springs but the cars are trustworthy, reliable and stable for a leaf car. Our focus is lowering front roll stiffness and increasing wheel travel in the front whilst leaving the rear end alone, because high rear roll stiffness keeps the car stable when climbing. We have no interest in suspension lift. Whilst there are cars around with much more flex, that doesn't translate to capability. My own car is coil sprung and has a lot of wheel travel and flex, but in real capability the biggest factor in my car's superior performance is wheelbase - I have 100" of wheelbase and that makes the car climb better.
Of course coil suspension will ultimately outperform leaf springs because once axle location is set by links, each element of the suspension can be isolated and adjusted. Of course my car with coils and extended wheelbase will make terrain look easier than a SWB on leaves, but I'm rarely driving something a SWB leaf car can't, my car just makes it look a bit easier - the body stays flatter and I can slow down a bit more - but as I pointed out, there are other factors at play there other than just the suspension. As an aside, I also don't believe in coil springs going loose either - that's the same as folding shackles.
  • Like
Reactions: 2
What replace shackles....and leafs.. LINKS. And coils or coilovers,....
And the giant post bove is pretty on point. Very valid Info relating to leaf spring setups, in general. Not just suzukis..
  • Like
Reactions: 1
1 - 8 of 8 Posts
