1 - 20 of 259 Posts
Vendor
Daves Offroad Supply can help you with all your Advance Adapters needs!
And we have BEST prices you will find anywhere!
Contact us for a quote.
Atlas 2
Atlas 4
RubiCrawler
SYE Kits
Toyota Doublers
For a quote...
PM me here
Email me at [email protected]
Call me at 484-554-3584
Quote Please
-Atlas 2 speed
-5.0 gears
-Passenger drop
-27 spline input
-Short Tail housing (no speedo)
-Heavy duty 32 spine front output
-1350 non cv front and rear
-Universal shifters
-Powerglide to Atlas adapter also
Shipping to Idaho Falls, ID 83402
Thanks
Vendor
Discussion Starter #3
Quote Please
-Atlas 2 speed
-5.0 gears
-Passenger drop
-27 spline input
-Universal shifters
Thanks
PM Sent, Thanks!
Hi Dave! I'm looking for an SYE and driveshaft for an 02 TJ with 3" lift shipped to 93722. Let's see if we can do business again!
Atlas 4 spd
Please quote:
4spd
Drivers drop
31 spl input
1310 CV yokes
Standard output housing
11.2 -1 final drive or whatever is the lowest one they offer.
Early Bronco shifters
shipped to 78738
Thanks
Alan
Vendor
Discussion Starter #12
Please quote:
4spd
Drivers drop
31 spl input
1310 CV yokes
shipped to 78738
Thanks
Alan
PM Sent, Thanks!
Vendor
Discussion Starter #17
Advance Adapters Heavy Duty Dual Bearing Toyota Crawler Kit
The new Tx2 double bearing design crawler adapter is designed for the 1979-95 Toyota Truck gear-driven transfer case. The adapter is made from a strong 356-T6 heat treated aluminum alloy and is 2.375” in length. The adapter kit includes an adapter housing, double bearing coupler, thrust washer, steel ball, two roller bearings, needle bearing, snap rings, gaskets, fastening hardware and adapter instructions.
Transfer Case
The adapter assembly fits the Toyota Truck 21 or 23 spline gear driven transfer cases. This transfer case has a male 21 or 23 spline input shaft and can also be identified by 7 bolts attaching the tailhousing to the transfer case.
Please give us a call or visit or on-line catalog for specific transfer case information when using the Tx2 crawler kit.
50-5905D Tx2 Crawler Adapter for the 21 spline gear-driven transfer case
50-5906D Tx2 Crawler Adapter for the 23 spline gear-driven transfer case
Vendor
Discussion Starter #18
Advance Adapters NP231 Slip Yoke Eliminator Kit
This Heavy Duty Slip Yoke eliminator kit fits Jeep NP231 transfer cases. This kit features a new 1 3/8”-32 spline rear output shaft, 356-T6 heat treated aluminum alloy tailhousing, 1310 c.v. yoke (other styles of yokes available), bearings, fastening hardware, and detailed instructions.
Note: Advance Adapters has designed our heavy duty fixed yoke output shaft with the most current design shaft found in the New Process Gear NP231. This current design shaft was introduced in 1997. Jeep vehicles using the early NP231 can still use our kit, providing that the needle bearings are removed from the stock drive sprockets.
1 - 20 of 259 Posts
