1 - 19 of 19 Posts
Long story short, I got ripped off on a 14 bolt because I was dumb enough to not pop the diff cover and trust the PO's word.
Ended up buying a 4.56 14 bolt with a gov lock. Gov lock is now broken and I need some advice as to whether it is fixable or not.
The gov lock mechanism was already removed by the PO (unbeknownst to me until I just tore it apart). The center ring that connects the 3 cross pins is broken. I dont think this matters if I weld everything together into the infamous "orb of traction".
What say ye?
Addicted to Gear Oil
It's screwed, keep the pins lined up with half of the case, add some heavy tacks. then flip it over and heavy tacks on the other side. Use the case halves to keep it lined up or you won't get the halves back together.
Auto part
Auto part Rotor Flange Machine
Auto part Disc brake Rotor Locking hubs Wheel
Auto part Flange Machine Wheel Tool accessory
Auto part Gear Differential Automotive engine part Hardware accessory
Save some money, because you're gonna need it for a new center section eventually. Find a stock center section, drop in a detroit, or ARB.
Thats what I planned to do. Just wanted to verify that the center section being broke isn't going to affect anything. I figured it wouldn't if I'm welding it all into one big chunk anyway. Just have to take it slow and let it cool slowly in some sand or under a welding blanket maybe.
id run a mini spool before i ran a full spool because imo the design of the stock carrier is going to have less deflection under load then a full spool will due to the lack of any ribbing on a spool.
That's a good point. I plan to use that spare carrier at some point and I agree with your logic. For now I'm just trying to get it back on the trail. Using the 3.73 carrier means I'll be into a 4.56 thick gear set. I plan to tear down the jeep this winter to 3 link the front and step up to 5.13's so I didn't want to have to buy gears twice for the rear this year. I can use the other carrier at that point and swap in a mini spool at that time.
Discussion Starter · #19 ·
Got some heavy tacks laid tonight and bolted the case halves back together then wrapped it in a canvas tarp to help it cool slower. I'll lay some more metal glue in it tomorrow tonight and call it done.
1 - 19 of 19 Posts
