1 - 1 of 1 Posts
Guys looking for some input on how you would mount this new cylinder on this set up.
1979 IH Scout II w/ partsmike gm 1 ton high steer set up.
Ive done some research and noticed some people run the ram mount off the diff cover, some off the axle itself, some off the U bolt plates.
What I am thinking is running the mount off the drivers side U bolt plate in the horizontal plane and to the tie rod in the horizontal plane. (heims flat)
Check out the photos I've added and give me any advice you want to throw at me. This is the first time I've set one up all I Know is you want the ram in line with the tie rod as straight as possible and heims flat for the best movement. (or so I've read via PSC tech articles.)
Thanks.
3107536
3107537
3107538
3107539
1 - 1 of 1 Posts
