1 - 1 of 2 Posts
Administrator
AEM INTRODUCES ITS NO-WELD O2 SENSOR MOUNT - JUST CLAMP IT ON!
Posted on 04.26.10 by Lance
Filed under Press Releases, and Tagged With: aem
Hawthorne, CA, April 23rd, 2010 - AEM is pleased to introduce its No-Weld O2 Sensor Mount, which enables users to mount an oxygen sensor without having to weld a sensor bung onto an exhaust.
WHAT IT DOES
The AEM No-Weld Sensor Mount removes the need to weld a sensor bung onto an exhaust when installing an O2 sensor for a wideband controller, gauge, etc. Simply drill a hole in the exhaust, install the gasket, and bolt the clamp. It's that easy! The kits come in 4 different sizes to accommodate exhausts from 1.75" to 3.5" in diameter. The mount will work with virtually any popular performance wideband sensor.
WHY YOU WANT ONE
This is the ideal solution for DIY enthusiasts who do not have access to a welder and who are installing a product such as an AEM Wideband UEGO Gauge, Inline Wideband UEGO Controller, or wideband air/fuel product from other manufacturers. It's also a great time saver for professional shops looking to improve throughput.
KEY FEATURES
  • The most affordable, hassle-free mounting solution available.
  • No more welding. Just drill a hole, install the gasket and clamp and go!
  • Available in 4 different sizes to fit exhausts from 1.75" to 3.5" in diameter.
  • Clamp band is constructed from 304 stainless steel.
  • Gasket is a graphite material with a stainless steel foil support and is heat resistant to 2500 degrees F.
About AEM
AEM Performance Electronics Products are engineered to Outperform. The company manufactures street and race products that are unmatched in performance, quality and value. AEM headquarters is located in Hawthorne, CA.
For more information please visit www.aemelectronics.com
[ News Home ]
1 - 1 of 2 Posts
