BlueCoyote3 said:22re conversion is 75% done.
Mounted the AFM on the RH side using a 84 Celica duct tube. However due to the cage configuraion, the AFM is at a 15 degree angle. Any issue with it not being horizontal?
Well I understand your question, and it does make sense to have it horizonital, but we are putting our trucks at all kinds of crazy angles, and it doesn't seem to affect the running of the engine one bit. I say try it!And does the AFM need to be horizontal?
Whatever size it took to fit inside the rubber hose, it is documented on the web page. I kept my AFM horizontal, didn't see any need to try anything different.BlueCoyote3 said:Thanks Roger. What size is that 45 fitting? All that stuff I found at Home Depot was either too big or too small.
BlueCoyote3 said:And does the AFM need to be horizontal?
