1 - 14 of 14 Posts
I cannot get my 88 Suburban to run right. It is all stock TBI. on a 70 350.
I had to swap out the entire wiring harness so Mabey I am missing something. But any way i set the timing at 0, With the set timing connector unpluged, Then pluged it back in. It will run for about 3 min then it dies. I cannot get my Code scanner to read any codes, it says(Communication Error). Any ideas where to start???
check your ground to your pcm..expecilly this. sounds like teh pcm isnt being read.
Is there suposed to be a Ground wire to the ECM?? Other than in the Main connectors?
no itll be in the main harness..
follow the wires from the connectors into the harness.
Discussion Starter · #10 ·
I have a GM wiring diagram, I found one Black groung within the Ecm Harness and it is grounded to the Intake.
Discussion Starter · #11 ·
Double checked all Grounds. They are all good.
no codes?
Check all the wires on the OBDI plug- IIRK you only need two or three to get a reading. You can also grab a "code reader" from napa or checker for 10 bucks that just shorts (or puts a resistor) on the correct way and codes will flash on your check engine light.
I'll see if I can find my diagram and send it to you.
Also, my 4.3L is set about 5 or 8 degrees advanced with the set timing thing unplugged. Not 0. The 350's may be different, but I doubt it.
1 - 14 of 14 Posts
