1 - 9 of 9 Posts
im twin sticking my 205, out of a 79 f250. ive got all the combinations working except for the front wheel only high. which of the two notches do i need to enlarge. ive pulled it apart about 10 times now, and im afraid im gonna take one of em too far. any other tips?
thanks
justin
i had those same worries and after a while i decided to rip it out and try again and i kept taking too little off but too little is better then too much just take your time man.
ii was using that article as reference. i'll keep at it tonite, just wondering if anyone knew which notch to keep working. i dont want to take too much off. thanks for the help though.
justin
when I did mine I got high tech. I resized the image of what they ground out on my computer screen. matched it as close as possible then tweaked it from there.
it was easy to do.
got it! had to make the notch on the end around 13/16'' not 11/16'' the article said. thanks for the help
justin
I did mine last night. I notched the end around 0.94" from the end and the middle around 0.4".
Works like a charm. Now to cut down a couple Dana 20 shifters I have laying around...
I am twin sticking mine right now and have every thing but front low only. I have been working on the sloped one in the middle because somewhere I read that was the one that I had to do but, know with the rear in low it will almostgo in front high :confused: so is it the other one that has to go longer. thanks
Discussion Starter · #9 ·
i finnaly got frustrated when i was doing mine. so i put the rail in and beat on it mercilessly with a BFH and when i pulledit out, it had a small indentation where it was hitting the ball that prevents you from making the shift. then ground that away. best thing to do, is to pull out your rail, get a light and look into the rail hole, put the other shifter in the position your having trouble with, and see which ball comes up, thats the notch you need to keep grinding.
justin
1 - 9 of 9 Posts
