1 - 5 of 5 Posts
Deralle engine oil cooler for Chevy. New in box From summit.
Will not fit my app. $65
B&M 2500 Stall Converter for T350 $75
Edelbrock Perfromer 600 CFM Carb - $125
Coarse Spline birfs $10per I have 5 total Will sell all for $45
1985 FJ-60 front and rear axles, complete - $275
1974 fj-40 rear axle, complete - $90
1986 Toyota Mini Rear axle, complete - $175
Radiator from 1985 fj-60 - $45
Radiator from 1993 Toyota T100 , was 3.0 - $40
Tranny/Transfer case from 1983 FJ-60 - $200
22r engine complete, good runner - $200
Weber Carb for 22r, w adapter and K&N (not the 38 mm)-$125
AC Pump off 22r/re engine - $45
Ac hoses from 22re and toyota truck - $25
High Perf alum intake for Pontiac 400 engine - $65
Serpintine belt setup for 350 chevy with TPI - $75
Email me at [email protected]
Thanks
hey
the weber is legal in WI :D
I am not sure as far as the smog and all that, but it should be legal. I can get any #'s off it, if that would help. It was on my buddies yota that was parted out after the engine puked.
Oil cooler is for Chevy v-8's and I am sure it should work with the v-6's. Basically it is a sandwitch plate that goes between the engine and the oil filter, then it has an inlet outlet line that runs to the cooler. I have one on my cruiser and it helped temps alot.
Thanks
1 - 5 of 5 Posts
