1 - 14 of 14 Posts
Put the meter on the battery, you should have close to 12 volts. Start the truck and take another reading should be close to 14 volts. This doesent check the alternator under a load so turn on lights, AC, etc, the volts should stay above what the battery volts were.
Some parts stores have a tester that should load up the alternator to see if its putting out what it should.
erich_in_AZ said:
Or go to checker or Autozone and have them throw it on the charging analyzer. It's free and easy, and tests under load.
Damn I sound like a salesman there! :laughing:
Thanks for translating this for me "Some parts stores have a tester that should load up the alternator to see if its putting out what it should.":flipoff2:
(my first use of the PBB hi sign)
I was a hell of lot more specific Newbie! I actually named a couple of stores, and mentioned the fact that it was free! :flipoff2:
Now, BACK TO YOUR CORNER NEWBIE BEEEEYOTCH! I'll let you know when you can speak again.
:flipoff2: :D :flipoff2:
TXLUGNUT said:
Don't like that method. Plus, I have the "theftloc" radio and if you disconeect the battery, it locks out and costs me $30 at the dealer to unlock it.........
I have a 97 vortec also and my theftloc was set by me so if the battery was disconnected i had to put in my code. Enter the code yourself and write it down and you won't have to pay to have it unlocked.
I have had these test show the alternator was good when it wasn't. Probably tester error if you go this route have some one experianced run the test. Or do what Elcyboy20 suggested
Newbe come out of corner.
OOPS! My bad, I thought the question was how to check it with a multi-meter. :confused:
Disconecting the battery is not a good check because it doesnt take much juice to keep a motor running. It only tells you that the alt. is putting out a little, but may not be enough to keep the batt charged.
Re: Newbe come out of corner.
Bwahahaaha! Just 'cuz that's what he asked doesn't mean we can't stray off line and tell him about things he doesn't want to know! :laughing: :flipoff2:
This is true. You can also spike the hell out of a computer (if a vehicle is so equipped) when you do this.
My experience has been that its better to take it off the vehicle, and take it in to NAPA and have it bench tested by someone who actually knows what the fawk they're doing.
Pete
IBJEEPIN said:
NEVER take the battery out of computer controlled vehicle why it is running!!!! Unless replacing fryed computer compents sounds like fun.
Yeah! What I said!
:flipoff2: :flipoff2:
Man, I can feel the love in here.
Feels kinda like brake cleaner, right in the eye.:eek:
Wonder how the alternator checked out???
1 - 14 of 14 Posts
