To bad the search is down cause I know I've seen lots of good info on this before. I did read thru the FAQ, found the link to autoshop101, helped some, but still not there yet.
I'm having problems figuring out the wiring of my '85 for the alternator. I have a diagram in a cheapy manual, but the color coding is way off and I can't seem to figure it out.
Looking at the 3 wire plug for the alternator, and basically, the '85 wiring harness doesn't match up with the same type plug (older donor engine, 20R). I have the older engine alternator plug, but I'm not sure which wires to splice together to make this thing work correctly.
Does anyone have a diagram that shows the routing and color coding for an 85 model, or for the 20R engine's?
Any help is appreciated.
