1 - 15 of 15 Posts
I'm about to put an 8.8 in my 4 banger. I took the axle to the local 4x shop the other day to have the brackets and such welded on. The owner questioned why I was upgrading from a D35. I thought he was joking. He said that the 2.5l doesn't have enough power to snap a shaft and that he runs 36s on his and hammers the shit out of it (lincoln locked) with no problems. I already bought the 8.8 so I'm not thinking about keeping the 35. I just wondered if he's right of full of it.
are you kidding me? <IMG SRC="smilies/emb.gif" border="0"> the only thing the 35 is for is a good boat anchor <IMG SRC="smilies/rolleyes.gif" border="0"> you never know, you may want to get rid of that 2.5L some day for a v8!
A 4 banger can snap Dana 35 shafts quite easily. It's not only power that can snap a shaft, but the precarious situations you can get into. The concern isn't only with the shaft size, but the housing strength, carrier strength, ring and gear strength...$hit...the Dana 35 lacking in everything!
First, find a new shop. This guy doesnt know what he's talking about. A dana 35 WILL break eventually if you wheel with it, even if you're easy on the gas pedal. I broke my 35 while on a winch cable, just idling up rocker-knocker in Moab. I wasnt even on the gas and none of the tires were stuck in a hole or anything. I guess it was just fatigued from lots of wheelin' time. Anyway, go with the 8.8 and don't listen to that jackass. <IMG SRC="smilies/biggrin.gif" border="0">
With a sick old Renix 4.0 I broke my D35c 4 times, open with 31's. I do tend however to follow the "when in doubt, throttle out rule." I swapped to the 8.8" with 35" swampers measuring 36", I could sidestep the clutch at 4500 and the 8.8" would not care at all. Keep the 8.8, if not for strength, then for disc brakes.
Hrmmm, i break nothing in my d-35... O wait, everytime i go out, i break a fricken carrier, spider gears, and a crosspin... have never however? broken a shaft although i carry 4 spares.. i too am going the 8.8" route by the end of the month... Measly 33" tires and an open diff, im not even throttle happy...
Ask him if he wants to buy a slightly used D35 for around $800.00 if he likes them so much. I would find someone else to deal with!! <IMG SRC="smilies/eek.gif" border="0">
1 - 15 of 15 Posts
