So I'm still trying to build this god damn Bronco. It's an 86, with a swapped in 302.
I got it because it was cheap. It was cheap because it was dumping coolant out of a freeze plug. Of course, the deeper I got, the more PO fuckery I found. The issue is overheat at idle. Let it idle, and after 4-5 minutes the temp just starts climbing.
Here is a quick run down:
--Build fan shroud (none present), install cheapo temp gauge in intake manifold (factory inop). I notice radiator only heats in certain areas >>> plugged with stop leak
--Flush radiator (x2, off vehicle), install t-stat (deleted by PFO). Still overheats.
-Replace clogged, single core radiator with new two core. Still overheats. Bubbles noted at radiator inlet. Gas analyzer shows HC levels rising in radiator at idle.
--Replace head gaskets. Straight edge & visual on block and head appear ok. Water pump impeller isn't awesome (small rust hole), so I replace water pump. Here is where it gets tricky.
The engine in my truck seems to be a carbed 302 (cam driven fuel pump), with a serp belt.
80-86 water pump doesn't match what is on the engine, so I get an 87+ pump. We (by this point I have called in friends smarted than myself) notice two things with this (later) pump:
**Impellers look backwards (maybe thats the original issue? serp belt coversion spinning original pump backwards?)
**Water ports/back plate do not match.
So we mix and match backing plates to try and make it work. Still overheats at idle. With new rad, tstat, head gaskets and new waterpump. By this time it's pretty late. I tried to sniff the radiator again, but it was inconclusive (HC in and out of rad, likely exhaust). I did a combustion leak test (blue fluid) and it came up negative.
I need to pull #s off the engine, but I'm getting discouraged here.
Would the wrong water pump cause over heat at idle? If so,
Would a small rust hole on the correct water pump also cause over heat at idle?
What other application uses a small body water pump? The pump on my bastard engine is the same size as an 87 Bronco 302, but different impeller and port configuration. What could it be from?
I guess this is my main question. I'd like to try this pump.
Or, am I missing something else?
:beer: for reading my babble.
