1 - 12 of 12 Posts
I have a built Yj on Chevy 1 ton axles. Right now I'm running an AX15 mated and clocked flat to a Dana 300. My ax15 is shot and I want to go to an auto. I already have a AMC 727. I know it mates to the 4.0 and to a Dana 300. I am 4 linked front and rear with double triangulated set up. So I am already running a 2 piece front shaft with a pillow block. Can I still clock the Dana 300 flat?
Another question... Will the 3 speed be suffice for 5.38 gears and 42s?
Here's a pic of the ride
· Premium Member
Yep, it'll bolt up, 300 will clock...but how about the crank sensor mount in the bellhousing? Don't forget about that.
Really, I'd install a TF999 (32RH) from a YJ or TJ. Ran one behind a 360 in my old YJ for years with great results.
Check with Hesco, they were having probelms getting harmonic balancers a few months ago because of their supplier...I would check with them before putting it all together, I had to buy mine off of a forum.
I had a 360/727/300 and my 300 hung down a little. I know guys buy the clocking ring to take care of that. The biggest issue I had was tranny pan clearance. But, if you have a 2 piece up front, that is a mute point.
1 - 12 of 12 Posts
