1 - 20 of 24 Posts
well one too many rolls for the 4runner....the body was junk, so i stripped it down and have been swaping a single cab on to the frame.
here is what is left of the body
here are some pics of the frame i have been cleaning up and installing a 4-link in the rear and installed dual cases and sold my 4.7 geared case
here is my diff guard that is an 8" pipe cap
installed the single cab today
here are some better 4 links pics
Discussion Starter · #13 ·
my upper links are 75% of the lower links lengths. The Lower links are 4', so the uppers are 3'.
the coils are stock jeep tj front coils. It is pretty stiff, so after i get the tool box and rear tube bed on I am going to see if i need to go to areo star coils or not
Super Moderator
'82 Scrambler, '14 Rzr
Looks good :)
Are the coils captured on one or both ends?
Discussion Starter · #17 ·
on the top, i used the stock bump stops and drilled a hole into them. Then i took two t-case flanges, cut the splines off of them and welded a washer on the inside, then i could put a bolt up into the bump stop and it would capture the coil. It actually work awesome.
for the bottom, i am waiting on some XJ bump stops i won on ebay, i am going to weld on some tubing to the bucket on the bottom and put the bump stops in. so hopefully i will not over flex the springs and have them pop out, but i will add limit straps if that is the case.
Super Moderator
Can't see in the picture here, but buddy of mine captured the coils at the bottom, use a tube w/ bumpstop at the time, and used a small piece of cable w/ clamps to keep the coil from dropping off the bumpstop tube used to align it.
Anyone see a problem with capturing the coils top and bottom? Would limit flex, but seems way more stable and less noisy/banging around from loose coils.
The only real problem I have found,is that it wears out the springs faster. That and some would argue that the axle wouldn't have the full weight on the tire at full flex. It would cause the spring to be pulling up on the axle...
1 - 20 of 24 Posts
