as i said last week... had a semi flat pitman arm on my toy and my leaf spring over flexed and broke it.....called marlin had him make a flat pitman arm for me...got it installed it...now shit...when i put marlins tierid end through it the nut on the top hits my frame rail....so i cant turn left...my question...the easiest fix i figured is to bend the pitman arm...its make out of thick metal plate... when and if i decide to bend it...do i need to make sure the hole for the tierodend is parallel to the ground if you know what i mean..if i just bent it down will it make the tierod movement awkward or am i just overthinking? what would you do??? cant put drop arm on it...hits leafsrping on stuff...and yes im gona put a bump stop on it now...any info would be great if you know what im trying to get across...thanks!!
