1 - 3 of 3 Posts
Guys
I am trying to make an e-brake for my Atlas T/case. I specifically want a drum style one for the increased surface area and I have figured oout how I will do it.
Any way the question I have is, have any of you guys pulled the rear housing off of the back of the atlas. The bit that holds the speedo drive gear and the drive flange??
I might need to remove this completey in order to make the brackets and don't want a heap of needle rollers or something falling out when I crack it.
So what do reckon. Can I remove it and then be able to put it back on, or will I stuff it up??
Thanks for the advice guy.
Regards
Rod
1 - 3 of 3 Posts
