1 - 5 of 5 Posts
Before i make the severe grind on my d60's(snowfighter & hd 60 )i would like to know if there will be any problems with 'spreading' them for gear set-up.i know 20 thousandths is'nt much for a maximum spread , but just wanted to check out beforehand if anyone has had problems. thanks......JJ
Yes Kris,I whole-heartedly agree! thats why I'm gonna do the shave and run 37's. Thats plenty for me! I just want to know if there is a problem with stressing (the housing) that I should be worried about, it'll be a shame to get that far, and hafta fix the axle housing again. ...Anybody?
um a regearing usually requires a full reset of the backlash to do it right, as does a new carrier, spool, locker, etc...:shaking:
most of the time you dont ever need a case spreader. I wouldnt even use it unless you absolutely had to. so go ahead, shave the shit out of it.
1 - 5 of 5 Posts
