yes, there was a stock one, but it hangs below the axle. The one WH has sits high and in front so when it is not connected there is no negatives off road.Oatmeal said:I believe they were factory installed on some of the later EBs maybe try one of the Bronco wrecking yards like Jeff's Bronco Graveyard or........ I'm assuming you were interested in street performance.![]()
It was alredy on the loose side but it is now alittle worse.yellowbronco said:Did that wristed axle make it a little floppy on the street?
