1 - 20 of 43 Posts
As I sit here daydreaming about that cool 35 spline disk 60 MONSTER under my truck - just curious if the extra loss of ground clearance from a 44 actually gains anything?
On that note - can I see your shaved pig? <IMG SRC="smilies/smile.gif" border="0">
I got the HD model so that means more casting to grind...
[ 09-27-2001: Message edited by: Brandon ]
Originally posted by Brandon:
<STRONG>As I sit here daydreaming about that cool 35 spline disk 60 MONSTER under my truck - just curious if the extra loss of ground clearance from a 44 actually gains anything?
[ 09-27-2001: Message edited by: Brandon ]</STRONG>
hmmm. lets see, you have broken, what, one birf?? man, i can't see you having any problems with that D44 even with the new motor.. if nec, go alloy shafts.. Thats what i plan on doing with my RC44...
Ya, i noticedthat after i posted, DOH!!!
well, if you are going to run at least 38's, i would go 60, but I prefer the 44 myself..
with alloy shafts, it will hold up well, and with the way you drive, it will be fine..
I broke a couple axles on a 44, but as soon as I went FF I have never broken another. FF 30 spline 44 will hold up to alot of abuse, especially with alloy shafts
Ask Wheelinjp to post the pic of his sheared off rear dana 44 pinion. It happened a couple months ago at Evan Creek ORV area here in WA.
The pinion snapped clean off. The jeep only did two little bounces on a very steep loose rock face then SNAP!
We got it on video <IMG SRC="smilies/bounce.gif" border="0">
He runs a sbc350, auto, and 36s w/ lockers.
He IS going to a dana 60 rear cause he now has one with 4.88s and a 40 spline spool sitting in the garage.
what benefit do you get running a foater alloy shaft VS a non float?? I know you can turn the hubs out unless you use a spline cap, but is there any benefits as in strength
IH/Rover Moderator
I have broke a few rear d44's. The heavy ass scout doesn't help. The spyders are the first to go . I broke one with 3.73s and 31" tires!
<STRONG>well I allready got the 60, just curious why everyone goes 60 (I am talkin bout the rear not the front)</STRONG>
I think it's as much for the stronger (1.5") axle shafts as it is for the stronger R&P.
4.09 '44s are a bit weaker than 3.73.. and it just gets worse as you stop from 4.56 down to 4.88.
The 60 would make sure the weak link isn't the R&P. As much as a broken axle shaft would suck on the trail, grenaded gears would suck worse.
Not as big of a deal up front, since (in theory, anyhow) most of the time the front, on average, has to share the engine output with the rear axle. But when in typical 2wd-Rear, the rear end sees ALL of it.
My owner's manual specifically states to NEVER use 4-low without the front hubs turned in.
Not that I follow that rule. <IMG SRC="smilies/biggrin.gif" border="0">
I've seen someone blow both the front and rear gears out in a pair of D44s before - at once. Not pretty. Nor cheap.
I think they were running 4.88s at the time and probably had the 38x11 Boggers on.
Then again, I also watched that rig stretch the U-bolts until the pinion pointed at the sky.. <IMG SRC="smilies/eek.gif" border="0">
I don't think it was from a lack of maintenance.. <IMG SRC="smilies/biggrin.gif" border="0">
Originally posted by Tankota:
<STRONG>Ask Wheelinjp to post the pic of his sheared off rear dana 44 pinion. It happened a couple months ago at Evan Creek ORV area here in WA.
He IS going to a dana 60 rear cause he now has one with 4.88s and a 40 spline spool sitting in the garage.</STRONG>
ya, but you ever seen him drive, oh, did i say that outloaud???
J/k sean..
Okay Crash, he does enjoy the go pedal a little <IMG SRC="smilies/biggrin.gif" border="0">
but who doesn't?
When he broke the pinion he wasn't really doing much...that is why it was quite surprising.
I've got a pic from a couple years ago at the entrance of the 311 trail at evans (when it was a wet wall of rock and mud) where he did a huge smoke show (tire smoke...not engine smoke) and made it up by drying out the rocks.
A one to two minute burnout really cleaned off and dried off his path up the rocks <IMG SRC="smilies/eek.gif" border="0">
The framed picture sits above the "porcelain throne" at his place. <IMG SRC="smilies/smile.gif" border="0">
Originally posted by Crash:
<STRONG>what benefit do you get running a foater alloy shaft VS a non float?? I know you can turn the hubs out unless you use a spline cap, but is there any benefits as in strength</STRONG>
Many people will claim that there isnt a great benefit to floaters, but I believe that there is. With a FF axle the shaft is not carrying any of the weight of the vehicle. It is simply driving the wheel. I personally run a flanged floater so that I dont have the notorious outer spline weak spot associated with FF axles
[ 09-27-2001: Message edited by: RCKRATZ ]
Oh yah, I almost forgot the blown spider gears in Wheelinjps dana 44 in the driveway <IMG SRC="smilies/biggrin.gif" border="0">
Just an excuse to buy a locker, right sean? <IMG SRC="smilies/biggrin.gif" border="0">
What were we doing anyway, were we checking axle wrap? (I think you had just finished the springover)
Originally posted by RCKRATZ:
<STRONG>
</STRONG>
Have you had any problems with the housing bending? I think the SF housings are generally a thinner-wall tubing than the FF housings - because the axle shaft carries some of the weight, not JUST the housing.
When you go FF, I think you're increasing the leverage on the housing, which wasn't designed for it.
I was thinking of the FF kit for a while and figured if I did, I'd first truss the housing to add some strength to it.
Turns out it was the front housing that needed the truss first.. <IMG SRC="smilies/biggrin.gif" border="0"> Should have the new front end in a week - trussed.
I know a guy who busted 2 ring gears in a rear 44 but he had a very heavy right foot. I have never had a problem with mine and I have 5.38. But then again I prefer to lock it down into 3500000000000:1 and just crawl. I have heard that scout rears are nutorious for bent housings, Im putting a truss on mine. <IMG SRC="smilies/jeep2.gif" border="0"> <IMG SRC="smilies/usa.gif" border="0">
Originally posted by tsm1mt:
<STRONG>Have you had any problems with the housing bending? I think the SF housings are generally a thinner-wall tubing than the FF housings - because the axle shaft carries some of the weight, not JUST the housing.
Turns out it was the front housing that needed the truss first.. <IMG SRC="smilies/biggrin.gif" border="0"> Should have the new front end in a week - trussed.</STRONG>
I haven't had a problem with the housing bending, but that may also be because I have a CJ-5, which we all know is a pretty lightweight rig. It may (I have no idea) be a problem on rigs with significantly more weight.
1 - 20 of 43 Posts
