1 - 6 of 6 Posts
Already searched up the Google (4crawler site) and the FAQ, got info but not exactly what I'm looking for...
I have been searching around for a simple checklist of Toyota torque specs and what all to check for before a ride. I am putting this on a excel sheet and printing a copy for the toolbox and glove box. Pass some out to some buddys so they can be as anal as me :flipoff2:
So far I have
Beadlock Rings
18​
High Steer Arms
80​
Hub Body
23​
Hub Face
10/120inch pds​
Wheel Spacer
90​
Wheels
90​
Motor Mounts
Crossmember
Driveshaft
Leaf Springs
and of course, the what did I Fuck with last:homer:
Anything else common that can work its way out when wheeling?
Here's a copy and paste from my list, mines on one tons/full hyrdo but you get the picture. My plan was to get a front to back list with socket wrench sizes and torques ect. but after doing this a million times I have the whole routine down. Usually takes 20-25 minutes and keeps me out of the dirt
Torque list:
Hydro fittings
Hydro heim jam nuts
*Steering arms
*Lower trunions
Tie rod ends
*U bolts front and back
Drive shafts yoke
Drive shaft flange
t-case crossmember mount
t-case flex mount
*Diff covers
Rear axle shafts
Transfer case to transmission
Adapter plate t-case
Hubs
FLUID CHECKS
brake fluid
steering fluid
clutch fluid
radiator fluid
diff fluid 1-gal frnt 1.5gal rear Gl5 80-90
trans fluid
t-case fluid 3-quarts Gl5 80-90
WEAR:
check heims for play
check drive lines for slop
check wheel bearings for play
air up tires crawler loading
check brake pads
GREASE:
grease ctms
grease king pins
drive shafts
tre’s
Torque list:
Hydro fittings
Hydro heim jam nuts
*Steering arms
*Lower trunions
Tie rod ends
Drive shafts yoke
Drive shaft flange
t-case flex mount
*Diff covers
Rear axle shafts
Hubs
FLUID CHECKS
brake fluid
steering fluid
clutch fluid
radiator fluid
trans fluid
WEAR:
check brake pads
GREASE:
grease ctms
grease king pins
drive shafts
tre’s
That is what's up! Thank you! If you don't mind, I'd like to steal sone of that list and add it to the OP so that future clickers and newbs can find it easily and print from one post.
And these checklist are made for the garage, before a weekend riding.
1 - 6 of 6 Posts
