I don't like Centerforce clutches. They make shifting at higher rpms more difficult as the weights are attempting to override you pushing the clutch in, therefore generally resulting in higher pedal pressure and slower shifts.
Unless you are a mud addict with lots of power and big tires, you'll probably be happier with a good quality heavy-duty diaphram style clutch. Just be careful not to get one with too high pedal pressure, as this is hard on crankshaft thrust bearings (and your leg, hehehehee!)
Also the stage III is a metallic lining which doesn't break-in, and is very 'grabby' with almost instant lock-up. This material is just like the metallic brake pads used on some race cars.
When we took apart my friends yota after only a couple thousand miles the flywheel and pressure plate both had .020" to .030" deep 'grooves' the width of the clutch disc facing material worn into them. However, his full metallic clutch never slipped!
