1 - 5 of 5 Posts
I made some for the rear of my Bronco, I cut off the little tab that goes in (on the coil to retain it) and just used a set of lower mounts I had to hold the coil. Also the ford trucks use a coil mount that unbolts, so they are easy to score from a P&P yard.
Call Factory Tubular, they built the ones I used to have on my Bronco adjustable and all, circle track idea. Get on their web site Factorytubular.com, at least I think that's it?
s2pid ****** said:
PM rockpuppy... he just fabbed his own buckets for some 5.5" coils...
I made mine our of 1/4" plate steel they work fine. I also made them 1" taller. is the frame flat sided?? if it is it will be easy to make... I used 6" wide plates the top plate is a 6"x6" plate with another plate cut diagonally for the triangular side supports..
1 - 5 of 5 Posts
