1 - 16 of 16 Posts
Hey H8monday, and anyone else that has one. Ive been hearing that the axle tubes can spin on the 8.8's if you dont weld them???
t/f?
<IMG SRC="smilies/question.gif" border="0">
No weld, no spin for me so far. Someone mentioned a while back that leaf sprung apps are more likely to have trouble.
Yup, I spun mine about 15 degrees on a, "hell bent to climb at any cost, rock" on the Spirit World trail above Bass Lake. There was quite a bit of hopping going on, and a heavy rubber smoke filled the air, when I made the top.
I welded the axle tubes, and have never had the problem again, even though I have hammered it at least twice that hard, with the V8.
I would stitch weld the tubes as a precaution at least. Its a piece of cake to weld them, its a pain in the ass, to seperate them turn em, press em and weld em after they twist.
i don't think i've spun my tubes but i tore them length wise at the front of both spring pads <IMG SRC="smilies/eek.gif" border="0"> , but of course this is in a full size bronco with a blown 351. <IMG SRC="smilies/biggrin.gif" border="0">
H8monday, so you welded it twisted when you got to the top of the hill? Did you have to drive on it much like that, anything get messed up? How exactly do you pull out an axle tube to reset it? Not that it makes a whole lot of difference because I replaced my 8.8 rear with a 10.25 <IMG SRC="smilies/biggrin.gif" border="0">
Hey SOCALXJ, i m just now getting ready for the swap into my 86 cherokee. I did weld the tubes to the pumpkin, 3 stitch welds.. I don't think i should have a problem with my 3.4 GM and a 50:1 crawl ratio.... I just did it because those plug welds look aweful dinky... Well, i should have the swap done this weekend, just gotta go pick up some u-bolts and a brakeline... Anyonw know what size that breather thread is? I lost mine... No biggy, i can go find one somewhere surely.... Hugh
Originally posted by BroncoRob:
<STRONG>H8monday, so you welded it twisted when you got to the top of the hill? Did you have to drive on it much like that, anything get messed up? How exactly do you pull out an axle tube to reset it? Not that it makes a whole lot of difference because I replaced my 8.8 rear with a 10.25 <IMG SRC="smilies/biggrin.gif" border="0"></STRONG>
I just removed the twisted side spring pack and used a ready welder to stitch weld the tube where it had twisted, then welded a 15 degree wedge onto the perch of twisted side, so that I could bolt back the axle, without torquing the springs. I drove it like that for over a month, before I removed the axle and had a shop straighten it all out.
[ 10-05-2001: Message edited by: H8monday ]
Originally posted by H8monday:
<STRONG>I just removed the twisted side spring pack and used a ready welder to stitch weld the tube where it had twisted, then welded a 15 degree wedge onto the perch of twisted side, so that I could bolt back the axle, without torquing the springs. I drove it like that for over a month, before I removed the axle and had a shop straighten it all out.
[ 10-05-2001: Message edited by: H8monday ]</STRONG>
Jeff,
Who straightened your axle for you? My rear 60 is spun and I need to get it fixed QUICK if I am going to make Frostoberfest. <IMG SRC="smilies/eek.gif" border="0"> Thanks! <IMG SRC="smilies/smile.gif" border="0">
When i was into Mustangs, i spun 2 myself, and firends all spun theirs as well, IMO, you have HP or bigger then a 35 you MUST weld it
Originally posted by RokHeep:
<STRONG>Jeff,
Who straightened your axle for you? My rear 60 is spun and I need to get it fixed QUICK if I am going to make Frostoberfest. <IMG SRC="smilies/eek.gif" border="0"> Thanks! <IMG SRC="smilies/smile.gif" border="0"></STRONG>
NO help, there, I had it done when I was in Vegas, by Dans Drive Line Service.
Call Gearman, and see if he can help you.
River City Diff, 852-7109
5,000 RPM drop the clutch launches all day. no tube spinning. I heard the same, but have not had mine do it. Knock on wood.
Originally posted by CaptainFleXJ151:
<STRONG>5,000 RPM drop the clutch launches all day. </STRONG>
5,000rpm? C'mon. What exactly do you accomplish by doing this? <IMG SRC="smilies/thefinger.gif" border="0">
<STRONG>Call Gearman, and see if he can help you.
River City Diff, 852-7109</STRONG>
I tried him awhile ago and he gave the thumbs down. <IMG SRC="smilies/frown.gif" border="0">
1 - 16 of 16 Posts
