1 - 16 of 16 Posts
Hey I have a LJ20 and I am having problems with the brakes. What I want to know is if anyone has built an LJ20 or so with different axles? I am wanting to put samurai running gear under it but the front axle will give me problems. The diferential on the sammy front axle is off to one side where the one on the LJ is in the middle. Anyone have anny ideas?
If the 20 is the same as the 80, and all you want is brakes, then use the outers from an SJ410 including disc brakes, nuckle assembly and hubs. Now you have disc brakes and free wheeling hubs.:eek:
The other thing you could think about is swapping out the t-case for a Sam/SJ t-case. I'm not sure if you'll be able to do that without a little hammer massage of the tranny tunnel.
You'll loose a little on your low range ratio but you can make up for that in a big way with aftermarket t-case gears and/or axle gears.
HTH
[email protected]
we have a guy in our club that has a Lj with the following
Sierra axles front &rear
Vitara 1.6 efi
twin transfer cases (vitara & sierra) oh sorry (sidekick & samurai)
extended cab
lockers f&r
Spring UNDER conversion
Rear OME springs in front with overloads and clips removed
3" Chassis extension
front bumpstops moved under chassis
Rancho 99012's all round 13" travel
10" chassis chop at rear
rear buggy leaf
new shackles
fuel tank moved ahead of the rear axle and moved turned around
2.5" exhaust inlcuding stack
2 new crossmembers
existing crossmembers reinforced
traction bars removed
rear axle braced
steering box moved 2" forward
high steering conversion removed - original drag link re fitted
30m of 1 3/4" 0.0106" (2.6mm wall) grade 350 CDS tube constructed
into front and rear stingers, roll bar, siderails and rear tray.
Sierra 1.3 air filter fitted, breathing through firewall
Doof Doof fuel filter and chrome inlet tube fitted ;o)
engine bay wiring loom er, tidied up.
battery moved to under glovebox
sierra washer bottle fitted
Front body mounts replaced with tubing off the stinger due to tyre
interference.
there is a thread in the Suzuki section LJ on 36s that has some pics. We are going out for a play this weekend so I'll have some action pics next week
Here's a buildup pic link
custom. The current owner bought it as a "finished" rig. Then we went and did most of the mods. What it had was the sami axles, sidekick engine, dual cases and the extra cab and a whole lot of bootie fab. Things like a tent pole used to extend the steering shaft and a tapered hole for the steering which had been beautifully done with a drill and a little side swinging drill action.
But the previous owner did do a pretty good job on the xtracab tho:)
Try checking out the LJ-10 website, here:
http://www.lj10.com/discus/
Lots of good info there.
I just bought an LJ-20 and was considering going to "full size" Sami axles, but then it wouldn't fit in the back of my pickup anymore. 5.66 gear ratio and third members same front and rear are nice. The SJ-410 outers work well. The 3:1 low range T-case aint bad either.
Personally, after considering many mods, I think I'll stick with small and light weight (<1400 lbs.) That's what makes these vehicles unique and capable.
1 - 16 of 16 Posts
