1 - 2 of 2 Posts
Wondering what the stock pinion angle is for a dana 44 front end. 3 degrees pointed up sound right? I'd just like to get it as close to stock as possible
The pinion angle should be the same as the t/c output within 1 or 2 deg. unless you run a CV type shaft. You should be able to just bolt it in & not worry about it. Unless you are going to cut & turn the knuckles, I would pay more attention to the caster.
1 - 2 of 2 Posts
