1 - 13 of 13 Posts
I need to find some new U-Bolts for my axle swap...
Kind of hard to measure them when they're on the jeep...
It's a stock '87 axle, with add-a-leaf's in the spring pack...
any ideas?
Man, I have em all written down at home. But then again I would need to know what axle your talking about.
Just head to any auto parts store, preferably a NAPA or better. Give them year make and model and they can index it real quick.
It sure would help to know what axle it is. Are you wanting the dimensions of your stock axle or the one you're swapping in?
[ 08-24-2001: Message edited by: cmegoup ]
Originally posted by DanH:
<STRONG>Well, the other kicker, is that I have an add-a-leaf kit in the springs...so they have to be longer!
How can I get around this?</STRONG>
Doesn't usually matter. Most replacement bolts are too long on purpose so you have to cut off what you don't need. Here's an idea for you. Try measuring the axle tube. If you can't figure out how to do that, hold a 2x4 or something on each side and measure the distance between them. Or just buy a couple, it's between 2 1/4 and 3 inches dependign on what axle you have.
I did some basic measuring. The guy at one store wanted the inside distance between the threads...
The rear axle has 4 same size U-Bolts. The front axle, on my '93 axle uses two different size bolts on each side. One is about 3.25" wide, the other is 2.5" wide. And they're about 7" tall.
The rears are 2.5 X 6.5" I think...
But this may all be different on the '87 axles, I don't know. I'm going to give Napa a holler.
Discussion Starter · #9 ·
I know I know, it's a sin to do it. But it's practically FREE!! I've got money coming in on the old axles, so I'm getting a gear "upgrade" for nothing...also get to dump the c-clip axle!!
It's not really an "upgrade", it's a swap, crap for crap!!!
For the 30 the smaller one should have 2-1/2" between the bolts and the larger one should be 3-3/8". Don't have a clue about the 35. Do you still have your old u-bolts? They should be the same size so if you do take 'em with you to the parts store to compare the new ones against.
I was gonna reply to Dan-H and ask what the heck are you doing swapping in new axles with u-bols on your brand new TJ.. then I seen where youre from... different DanH..
<STRONG>I need to find some new U-Bolts for my axle swap...
any ideas?</STRONG>
yeah, like I'm gonna put a leaf sprung Dana 35 under my TJ <IMG SRC="smilies/rolleyes.gif" border="0">
I'm not sure I'd put a Dana 35 under a trailer <IMG SRC="smilies/thefinger.gif" border="0">
- Dan
1 - 13 of 13 Posts
