this is whatI'm using, they came from (I think) a 1 ton dually. I originally installed them with 3 leaves and a chopped off overload and then later added one leaf back in so I could haul more weight. I can't tell the difference between the two on the road or trail until I put a bunch of camping gear in the back and the 4 leaf setup doesn't sag nearly as bad.
the bobbed yellow truck I moved out of the way when you came by here saturday had a set of these set up as 3 leaf packs.
the 1-ton packs are better, you have options.
[ 09-17-2001: Message edited by: scottz ]
