1 - 6 of 6 Posts
I just purchased a used dana 30 with an arb. My question is their any way to make sure its good before I install in the jeep. I do not have a compressor yet.
visual inspection. Look at the gear teeth.
You can also put a low air load on it from a normal compressor and see if the actuator (?) engages.
not really. the only thing you can do is find a way to get some air in there & listen for leaks.
arb
thanks for the input, I hooked it up to my compressor, it worked, but I did notice on the arb there was a gash in the side of the housing with a small pin whole that leaked air?
1 - 6 of 6 Posts
