1 - 4 of 4 Posts
I want to re-wire my front locker so that the rear one does not have to be engaged first or with the front. I want them to be separate from each other. I know its a simple task but can't find the directions a buddy gave me last year and he can't remeber either. So how do I do it?
Thanks
Its very simple all you have to do is pull of the wire that goes from you rear locker thats hot when the locker is engaged (it will also be going to the soleniod) and find the ignition wire the "heats" up the rear switch and also run it two the front switch also a simple test light should be enough to figure it out with.
1 - 4 of 4 Posts
