So i broke all 6 ARP hub stud and dowel pins
I swapped to a spare hub assembly w/stock studs, after some research I'm not so sure the ARP studs are worth the money.
isn't it true that the bolts(studs) in a bolted joint theorectically shouldn't take any of the shear load and only be loaded in tension.
Wouldn't cone washers create a better bolted joint and therefore better fit a bolted joint model?
thoughts?
I think as long as they're tight they should be somewhat equal (stock vs ARP)
thoughts?
