1 - 3 of 3 Posts
I'm wanting to swap out my OEM studs for ARPs. The celica studs seem to be the easiest if the .007" larger knurl isn't an issue. Has anyone done this with their Celica studs 100-7718?
I have done this upgrade. I left the hub installed on the truck. The OEM removed easily. I used a 6 inch Hargrave C-Clamp made a sleeve that I placed over the threaded end and commenced for good work out with the C-Clamp. Aline the splines of course. 007 doesn't sound like much of a press but with the size that the studs are it`s a heavy press. Removing the hub and using a arbor defiantly would be easier for press things together. My 2 cents.
I have seen these ARP wheel studs used in many different Toyota applications. They seem to be a direct swap for factory Toyota studs.
1 - 3 of 3 Posts
