BOOM!!!! JK UNDER ARMOR - 4 Door Bellypan Kits NOW AVAILABLE TO PREORDER!!! First 20 orders get $150 OFF and if you order today or tomorrow, our FREE SHIPPING SALE APPLIES! HURRY, this deal won't last long!
ORDER NOW - JK UNDER ARMOR - 4 door Bellypan Kit
Artec Industries' NEW JK UNDER ARMOR is designed to give your Jeep JK Wrangler full protection underneath the vehicle. Designed using CAD files directly from the manufacturer, this belly pan skid plate ensures that you have a great fit with factory components. Made from 1/4" thick 6061 Aluminum and 3/16" Zinc-plated Steel, and CNC cut and formed, the Artec JK Under Armor Kit offers both a strong and lightweight solution for the heavy Jeep JK.
*On 2012-2014 models, requires exhaust modification - Loop Delete/Y-pipe
2 Door Versions Coming Soon! All versions available currently only as complete kits. Individual skid plates will be available for purchase at a later date.
PRODUCT LINK
Install Instructions
- 1/4" 6061 Aluminum for skid plates, 3/16" zinc plated steel for bracketry
- Designed from factory CAD files for great and precise fit.
- CNC laser cut and CNC formed using custom rolled dies for high strength and a unique look.
- All bolts under skid plate are countersunk for absolutely smooth bottom
- All nuts are pressed into steel brackets for easy, one tool removal
- Modular design lets you take off only one section for vehicle servicing
- Protects Oil Pan, Transmission Pan, Gas Tank, Front Exhaust and Transfer Case
- No removal of gas tank needed, simply bolt in place
- Works best with Artec JK Heavy Duty Crossmembers*
- Clearanced near rear drive yoke shaft to prevent rubbing
PRODUCT LINK
