1 - 8 of 8 Posts
This is just a feeler for the time being... I have an Atlas II 4.3 passenger drop T-case adapted to a 27 spline th400 Tranny... I have been trying to save up for a hp dana 60 and I simply am running out of patience... My thought is if someone had a compariable driver drop case, it could be mutually benificial... The case is in great shape, I bought it from Adam Ant @ a&a fab, I know he would back up its condition if anyone wanted cared... I have all the shifter adapters, E-brake , cv output, and larger apline output... I am slightly naive when it comes to the particulars of this case, but I can look into anything if someone seems interested...
Give me a call if interested
~doug @ 916.224.3628
yup, all th400s were 32 spline outputs. there were a FEW ODDBALLS OUT THERE USING THE TH350 STYLE 27 SPLINE OUTPUTS. THESE TRANSMISSIONS ARE TECHNIACLLY CALLED TH375. THE ONLY DIFFERENCE IS THE OUTPUT SHAFT.........
FRIggen caps......
"All Weeee Drive!"
Ok, I'll bite....
The way I read it, you want to trade a PS 4.3 Atlas for a Ford D60?
Does it have the speedo output on the rear?
I have a 79 HP front 60 with 4.10s sitting in my shed...
I'm in the same boat as you, but trying to save up for a Doubler...
This might be a good option for next year for me.
Can you confirm the input?
I would be mounting it behind a 32 spline Sm465...
i have a complete d300/np241 crawl box setup
it is a 27spline unput and i have the adapter for it to bolt to a chevy 4 bolt ouput, IE 700r4 TH350
everything was fully rebuilt.
1 - 8 of 8 Posts
