1 - 20 of 492 Posts
hi bob,
do you have used divorced atlas for sale (passenger side drop / right hand drop for both front and rear) ? how much will it cost ?
Thanks
Vendor
hi bob,
Thanks
NO currently only have an empty housing right now. Haven't done any divorced cases from Atlas.
Thanks
CCOR
706-559-9609
Could I get a quote for:
Atlas 2 Speed
3.8:1 Ratio
27 Spline Input
Passenger Drop - Flat Rotation
32 Spline Front Output
32 Spline Rear Output, Short Tail, No Speedo
1350 Non CV Yoke Front & Rear
Universal Lever Shifters
TH350 Adapter
Shipped to business 28037
Thanks!
TH350 adapter
27 spline input
3.8 pass drop flat
standard shifters
HD 32 spline
1410 non cv yokes
no speedo
shipped to biz 37210
RFQ for the following items
1) Atlas 2 Speed Transfer-Case Specifications:
3.8:1 Standard Duty
Left Side Drop
32 Spline Input
GM VSS Tail-Housing
HD 32 Spline
1300 Series Flange Front
1300 Series Flange Rear
Shifter Cable Universal
2) Adaptor 50-9600 – 6L80E
Shipped to Business 15234
Vendor
Discussion Starter #10 (Edited)
Atlas 2 Speed
3.8:1 Ratio
27 Spline Input
TH350 Adapter
Thanks!
TH350 adapter
27 spline input
3.8 pass drop flat
standard shifters
HD 32 spline
1410 non cv yokes
no speedo
PM's sent
and more coming!
Thanks
CCOR
706-559-9609
Quote for Atlas 2 speed
Gear Ratio: 3.0:1 Standard Duty
Drop: Left hand drop (Driver Side)
Input Spline: 32 Spline Input
Tailhousing: Short Tailhousing (no speedometer provission)
Front Output: Heavy Duty 32 Spline
Rear Yoke: 1350 CV
Front Yoke: 1350 CV
Shifter Kit: Universal Left Drop
Tranny is Chevy NV4500, so according to manual the adapter should be 51-0205 or 51-0220 - price for both adapters as well
Shipped to: 33142
Thanks
Vendor
Discussion Starter #14 (Edited)
Rear Yoke: 1350 CV
Front Yoke: 1350 CV
Shipped to: 33142
Thanks
PM finally sent and sorry it took so long.
Thanks
CCOR
706-559-9609
Vendor
Discussion Starter #15 (Edited)
Atlas2 : Atlas 2 Speed Transfer Case (#Atlas2)
The Advance Adapters Atlas gear-driven transfer cases are the ultimate in gearing and strength. With over 10,000 units sold, the Atlas 2 speed is the solution for combining both on and off-road performance.
Don't sweat it, order in confidence knowing that after placing your order, you will be contacted by one of our technical specialists to nail down the specifics on your application before your order leaves the building. Shop online with confidence knowing you will get the correct transfer case, accessories & support to make your installation a positive experience from the start.
Thanks
CCOR
706-559-9609
quote for Atlas 2 speed
Gear Ratio: 3.0:1 Heavy Duty
Drop: Right hand drop (Passenger Side)
Input Spline: 23 Spline Input ( th400 with novak adapter and dana 300 bolt on )
Rear Yoke: 1310 CV
Front Yoke: 1310 CV
Thanx
Vendor
Discussion Starter #19 (Edited)
Rear Yoke: 1310 CV
Front Yoke: 1310 CV
Thanx
Did you get my PM?
Thanks
CCOR
706-559-9609
1 - 20 of 492 Posts
